unconfigure sflow agent
Description
Resets the sFlow agent‘s IP address to the default value.
Syntax Description
Default
The default IP address is 0.0.0.0.
Usage Guidelines
This command resets the sFlow agent IP address to its default value.
The following command resets the agent IP back to the management IP address:
This command was first available in ExtremeXOS 11.0.
Platform Availability
